Has anyone else had problems getting a grease gun tip on to the fitting on the front driveshaft? The one that you can get to from within the car under the rubber blank behind the shifter? I have tried with three grease guns and it seems that they are just a little too thick to make a good connection to the grease fitting. I will think that I have it on there and then see the grease oozing everywhere but into the fitting. I thought I had it made when I came across a needle attachment that is made for greasing seals without grease fittings but I only succeeded in breaking the needle off. I also began to grin down one of the grease gun
tips but I lost patience after a few tries and still could not get it on tightly. Is there any such thing as a temporary sort of fitting that would protrude more out of the joint (just be longer in length) to give me the clearance I need. I have not seen any at my local auto store.
Thanks very much,
Jim Lee
Thanks very much,
Jim Lee
