Gravel Roads
SaxMan
I spent Labor Day plying the roads of Western Montgomery County, crossing the Potomac on White's Ferry and poking around northeast Loudoun County, Virginia. I was trying to recreate a bike ride I did some years ago...but couldn't remember the exact route. Nor did I remember that some of the roads I rode were gravel. This was the first time I had Baby Blue on gravel. My thoughts:
1. It's LOUD! Hearing the rocks hitting the wheel wells and underside of the car without any kind of sound deadening was a bit a surprise to me. I cringed almost the whole time. Every once in a while, I'd hear a "ping" of a piece of gravel hitting the exhaust pipe.
2. Fun, but tricky. On gravel, I could slide the rear end out almost at will by downshifting. A little scary when the car would start to "float", like hydroplaning on small rocks, but really fun around some hairpin turns. I can't imagine what it would be like to take one of these cars out on a dirt track. With a bit more power, they'd probably make great drifting cars. Probably just as well that they don't, though. They'd get snapped up and expended if they were.
3. It's dirty. The poor car is covered with dust. Even more so when I passed a car going the other direction and had to go through his dust cloud. The nice thing about these cars being so small is that it takes no time to wash them!
Glad you had fun. S ounds like the cleanup was fun too. Don't be surprise to see little areas of gravel and dust next time you crawl under.
Yup, I drive my bugeye on gravel roads occasionally, and I find rocks in the engine compartment and resting in all sorts of nooks and crannies. Do not down shift on a slick surface unless you have the engine revs matched ... even then it is sketchy with the heavy flywheel on your car.
My "driver" 66 does gravel and dirt regularly. Not a straight panel on it though just a hint of rust. Makes it my favorite car!
Kurt.
Crossing White's Ferry last fall with Joe McGinnis and his Sprite😄
Apparently it was more turbulent then I remember
Took the roller coaster loop across, might as well make the trip fun. Too bad with the tops on you can't see them holding their arms up...
My home driveway is a bit long and gravel where it is level. Leaving home ain't so bad. Returning means the
Dunlops have heated. Those tires look like they are sugar coated with fine gravel. I have found gravel under
the bonnet on the inner fenders. Getting the rear end loose on the way out is always a hit with the passengers.
I am just resigned to the wear and tear. Love the crunchy sound coming home.
I once met a paroled bank robber who, upon making parole, bought a new big Healey. Long story short, he got drunk
and on a bet barged into the local dirt track and lead a lap or two before trying to get away. Last I heard, which was in the 60s, he was returned to prison.
sliding around is always fun.
