I've always used grade 8 bolts on my equipment whenever possible, because of (shear) strength mostly. One of my tractors uses a through bolt on a PTO shaft that takes quite a bit of torque on the nut. I didn't have any grade 8 nuts left so I used a new grade 5, when torquing it up the nut stripped way before the proper torque setting and damaged the bolt threads. If using a grade 8 bolt, use a grade 8 nut! Just thought I'd put this out there for future reference. PJ
