Well, I finally found the time today to install the new water pump in the spit, but still have a small problem. My temp gauge doesn't work. I took the sender off and tested it in a pan of boiling water and it seems to be working. Also, the resistance at the connection to the gauge seems to change as the tem rises, so the wire from the sender to the gauge is good. Also, there is 12 volts at the other side of the gauge. So I am thinking that maybe my gauge is shot? Thoughts?
