TR2/3/3A Got the new TR3 home tonight -- observations
sammyb
My friends Bret and Adam accompanied me to go get the '59 TR3 today. I also transferred the title, and attempted to change the title from '60 (date of sale) to '59 (date of manufacture) with no dice.
Since Bret's extra tow truck was out of commission, we used a good old fashioned wheel dolly. It actually worked well to free up those dragging wheels! (Smell those brake pads!)
When we got up to my street, Adam jumped into the TR3 and on the second push of the clutch, he was able to engage it (clutch works!!!) He let the clutch out and the frozen engine (with anti-seize sitting in the spark-plug holes for two days) freed-up!!!
So we pushed it down my hill into my garage -- brakes work.
The car was very obviously originally Powder Blue with Blue interior/white piping. I actually wish it was still this combo, since I happen to like it better than BRG/Black! The interior has been painted black. The carpets are quite good. The center panel needs to be painted in correct wrinkle black.
There are a lot of little MacGyver home built things on this car. I took off the home-built wind wings, as well as the ugly (and broken) coolant overflow.
Mostly the car is just plain filthy. There's so much junk on the underside of the bonnet that I'm simply going to take it off and wash it outside so it doesn't all fall into the engine, which I'm making progress on cleaning.
There are some scrapes, scratches, and the obligatory repaired with fiberglass battery tray, but no other rust that I've seen so far. The hubcap chrome is toasted, but I think these are repros, since they are very thinly chromed.
Otherwise, there are a bunch of parts I'll need to assemble, and a tushy-load of cleaning to do.
After a coolant flush, gas tank flush, oil change, spark plug change, rear-end oil change and a new battery I'll try to fire her up.
Sam,
I fired up the engine on my car after flushing the radiator and refilling. I let it run until the temp came up to see what the oil pressure was (70 psi warm idle)....and then I noticed the temp gauge kept climbing, so when it got to 200 (and climbing) I shut it off. Now that I'm dismantling the car, I can see why it was overheating! The inside of the radiator hoses were filled with what looked like play doh! I guess the anti freeze mixture must have congealed after 22 plus years of sitting in an unheated bard in Rochester NY. I just wanted to make sure you took a look at the hoses and such. The inlet to the water pump on mine was filled with this same gunk. Once I get the engine out, I'm going to have to flush the block real well to get rid of all that I'm sure...good luck with yours, and send more pictures when you get a chance! /ubbthreads/images/graemlins/hammer.gif
