Got the '76 B that I bought two weeks ago running today. It'd been sitting in a concrete floored garage for about 2 1/2 years... i drained the tank (which was full with stale gas but since it was full, no rust had developed; changed the oil; sprayed some WD40 in the cylinders a few days ago, spun the motor for about 5 seconds with no plugs today; reinstalled the plugs & put some fresh gas in & it started on the second try (& on the 1st try i'd forgotton to reconnect the coil lead to the distributor!)...
Didn't seem to want to go into gear & clutch didn't engage till the pedal was only an inch or two from the floor so not sure the clutch is good. Supposedly the clutch cylinder was rebuilt (& fluid is clear) but i guess it could be the clutch slave or it might just be tight going into gear (i doubt that though)...
Anyway, I didn't try to push it into 1st or put it in first before starting because the car is in my garage & my other car was right in front of it on the driveway... didn't want it jumping forward into my suburban!
So, I'll play with it tomorrow after church (& after checking the trans oil level - something I should have done before trying this anyway of course). With luck the clutch will be ok & I can run it through the gears to check out the trans.
It started up way easier than I expected so I'm happy!
