I've had Richards brackets on my car for around 6 years with great results. Just this past winter I started to notice a clunk from the rear of the car. After inspection there are no broken welds, mounts, loose shocks or bolts, binding axles, or deteriorated bushings. The bushings are all Nylatron, swing arms and Diff mounts. I have the original mounting instructions but information on the spacers between brackets and the bushings are a bit vague. If I grab the arms and try to move it side to side I have no deflection. This seems to be the only area that may be causing the clunking sound. I checked his site for a more updated and detailed instructions but nothing could be found.
I never had to do any repair to the differential other than oil changes, and seals. I don't think the differential is my problem.
Has anybody with these mounts had the same problem?
I forgot to mention no bad u-joints.
