Jim_Gruber
I was able to finally get the Bugeye Bonnet to fit on Bugsy my '68 Sprite for the first time last night and the Front Hinged Bracket does indeed work. It is truly a case of "File To Fit" however and lots of work will be needed on panel fit.
That isn't my problem however. Anyone got a good method for getting the curve and the top of the bonnet / base of the windshield back into a bonnet. This bonnet is absolutely flat up at the top. Now I've added a piece of trim moulding sitting in the rain gutter ledge back by the firewall to raise up center of the bonnet for clearance purposes and loosened the bows/stays under corners. Corners of the bonnet are now sitting perhaps 2" above the body. Now I will be using latches on both sides at the rear but short of clamping this baby down and hoping it takes a proper shape over time, anyone got some tips on getting some curve back in the bonnet.
I should probably add that this bonnet has been off of a car and standing on end for probably 15+ tears.
