Wire-Wheels
Life has slowed down a bit so I can address some of the chronic problems plaguing my TR-6. I got its clutch issues worked out last month with a redesigned clutch rod I whipped up on my mini-lathe. I also have the oil leaks stopped for now. The last one turned out to be a leaking sender I had installed for an oil temp. gauge, [just not tight enough]. This month I installed a new diaphragm in the driver's seat. I found them at The Roadster Factory in Pa. I am glad I bought some of the pieces for this car early, as prices are going up. This winter I want to take the interior apart and fix a few things. I have all LED dash lights waiting to be installed. I need to address some wiring issues under the dash too. I also want to fix some of the weather stripping the previous owner had installed [but not securely enough]. I also think I might install a pair of Smith's rally timers I have had stashed away for a few years. Mechanically, she is running pretty good [for now]. I want to keep it available for the occasional warm winter days this year. ...J.D.
Hi Guest!
