eurobiketrash
Member
I removed the tach today from my 66 3000 to find the wire that is the induction loop cut on both ends. So I begin to try and find the rest of the wire that should go to the ignition switch and to the coil.As I keep trying to trace down everything I start to think that the wire was reconnected together just bypassing the tachometer, and one end of the wire is at the coil and the other is on the ignition switch.
My problem is this.Im not a whiz with electrical troubleshooting, however; I know that my battery is connected in positive ground configuration with positive cable to the battery shut off then from shut off to chassis. When I check the coil with the ignition on, the positive side of the coil is showing voltage and the negative side is basiaclly showing zero----shouldnt this be the other way around?? The negative side should show voltage shouldnt it???
Hi Guest!
