BN1L_156424
Member
Hey there.
A couple of weeks ago, I was finally able to procure my mother's rust free 54 BN1 (which she owned at age 18), which I used to sneak drives from when I was 15 but I haven't seen it in years. The car has been sitting for nealy a decade, so it is need of a decent amount of work. I'm not all that experienced with car work I am a decent mechanic, so can take on some decdent sized jobs.
Looking over the car, the following things need to be addressed. Keep in mind, my current goals are getting the car safe for me and the car to drive, and preventative mantainance. Authenticity may be a good goal, but for now I am just trying to avoid having to modify the car for retrofits.
1) The brakes are really bad, according to my mothers old flakey mechanic it needs new pipes, which I have ordered, the authentic pipe sets from Moss were out of stock so I got the "competition" set. Does anyone have experience with these, good or bad.
2) There is a leak in the transmission, such that the OD unit will not keep pressure. Having read some posts, it looks as though I need to pull the thing out and replace some seals and gaskets. How many weekends should this job take, or how much should I expect to pay to have someone else do it (I can add my own San Francisco markup)
3) None of the gauges or lights seem to be working, (and I have forgotten what the mystery switch under the facia panel below the overdrive switch does). Are there any obvious places to start looking for that issue?
4) The wire wheels have a good deal of runout, and probably need replacing. I am actually thinking of going the Alloy wheel route, maybe I just need someone to save me from that.
5) While the car is garaged, I live in san francisco, which means if I drive it somewhere and park it on the street for too much time, the finish and badges will be in jeopardy. However it hasn't seen paint in 25 years, and much of it is falling off the aluminium body panels, and some spots off the steel. How much should I pay for a maintance coat (probably the aluminum sections will need to be blasted as they were not properly prepped on the last coat). Should the boot badge read "Austin of England" VS "Austin Healey"? I think the car was built in May of 54. (I had seen just a week or so a go a webpage (sadly I can't remember exactly where it was) which had the dates and changes of cars listed by approximate Car Numbers)
6) Anyone have an easy way to install the gasket on the bottom of the fold-down windscreen? It's possible that the new one that I found in the door pockets is just a bad fit.
I have standard, metric, and whitworth, sockets and combination wrenches, mallets, worklight, floor jack, heavy jack stands, multimeter and standard tools. What else should I get before I start these jobs, or will probably need soon?
Thanks
joshua winsor
jwinsor@gmail.com
Thanks
joshua winsor
jwinsor@gmail.com
