mastaphixa
The subject of this post is a 1960 Triumph TR3A that has been converted to a motorcraft type alternator with an external regulator. It has been operating normally for years. Recently the red generator light illuminates with the engine running. With the ignition on/engine off the light is on dimly and after engine start the light comes on bright. The ammeter shows a positive charge and that is confirmed with a volt meter. With the engine off battery voltage is 12v and change. After engine start a voltage of 13-14v is displayed. I have had the alternator checked and it is operating normally. I have a back up voltage regulator and have swapped it out with no change. When I swapped the regulator I noticed the removed regulator (l'll call that regulator #1) had lots of corrosion on the terminals. I installed the spare (regulator #2) and the car was back to normal. I removed the corrosion from the terminals of regulator #1 and reinstalled it and the car was back to normal. Thinking I had fixed the problem I enjoyed a beverage and patted myself on the back. The next day I started the car and I was back to square one with the light on again! While the engine is running I can hear the belt make a little noise which goes away if I disconnect the wire from the I terminal of the regulator and the generator light is off at that point. I must admit I am a bit confused at this point. I have checked the battery with a load cell and it is healthy.
Any help would be appreciated.
Hi Guest!
