Next question - is there a problem with generator brackets, or is it just me? Have to admit, the first one I had was a little misshapen, and after 20+ years broke a piece off the back end of the generator (healeygal technical term - "end piece") where it bolts to the bracket. The replacement bracket looked nice and straight, and fit the replacement end piece very well. There was, however, a problem with the nuts vibrating loose, so went back and they put on lock washers. That worked well for a year to two, until last week when the car was in the shop and the mechanic noticed a crack in the bracket and welded it, so we'll see how it goes... The car rides very steady and stable, no problem with scuttle shake at 55 or rattling when I go over railroad tracks - the shocks are about 3 years old, sway bar work done then, too. I often check the belt, and there is always a good amount of play, so I was wondering - is this a bracket problem, vibration problem or just a healeygal problem?? /ubbthreads/images/graemlins/confused.gif
Sharon
BN1
Sharon
BN1
