Gearbox Sealer
sail
Since goop has come up tonight, Hylomar on gearbox/adapter plate/od paper gaskets and nothing bellhousing to engine? Anything on studs and bolts? Goes together tomorrow and moon is in waxing gibbous if that makes a difference.
That's what I use.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Anything on studs and bolts?[/QUOTE]Only where they need to seal against liquids, like the 6 bolts inside the bellhousing.<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Goes together tomorrow and moon is in waxing gibbous if that makes a difference. [/QUOTE]Save the blood sacrifice for about 3 weeks, then. Oh wait, that's for electrical ...
If you don't seal in a new moon then it won't work.
