Went to install the clutch and gearbox today and am delayed by not ordering a new spigot bush which will be required. Anyways while installing new gearbox mounts I noticed that one is larger than the other. Upon further investigation I also noted that the brackets which they attach to are not symetric. Both gearbox mounts are the same part number, and the catalogue does not specify a difference of right side/left side mounts. This could be a matter of inconsistent manufacture. Does it matter which side the larger mount is installed or am I just overthinking this situation?
Thanks, brdave
Thanks, brdave
