I'm putting the TR3 away for the winter and now have, for the first time in my life, an insulated garage with heat. The problem, which was never a problem in previous drafty and cold barns, is the fumes from the TR3.
I've pretty much ruled out leaks and fixed the one I did find.
I am quite sure the culprit is the vent. I get a good whiff if I put my nose near the bottom of the vent tube. The tank is close to full, but not overly so with 60 or so miles since fill up.
Do I just ignore this? Drain the tank and system? Plug the vent or put some kind of charcoal filter on it?
Your thoughts will be appreciated.
Tom
Tom
