Bret
Gaskets?
OK,
For those of you who are lucky enough not to have a MGB equipped with a catalytic converter (75 to 80) as my 78B is - feel free to ignore this question.
Anyway in preparation for my B’s upcoming smog test – I am doing some house cleaning. One of the things I discovered was that the Gasket between the Manifold and the top of the Catalytic Converter was leaking. Figuring no big deal I’ll just replace it. Ordered a replacement from Victoria British (P/N 1-780) and from my Moss (#297-550). The gasket from VB arrived first so I naturally started tearing down things to get at it. This was a much bigger thing that I originally figured but that’s another story for another time.
To the point – using the gasket from VB I reassembled and proceeded to work on other issues related to my smog test. After about a half day of tweaking my Stromberg with little luck (again another story) I started to hear what sounded like another exhaust leak. After a little more time the noise got more and more pronounced to the point that I was finally able to see what the problem was.
The VB Gasket had completely burnt away!
Has anybody ever seen this before? This weekend I will try to install a new gasket this time using one of the heartier looking ones that came from Moss.
Any feed back welcome.
Bret
PS Almost forgot to mention. My Cat was completely blown out & I have ordered a new one from Moss. While this might be a tell-tail sign of what happened to the old gasket - I don’t think the completely open converter could have affected the new gasket. Any more thoughts?
PSS According to Moss the new Cat comes with a Gasket. It’d be interesting to see what the difference is between what I ordered from VB.
OK,
Bret
