Richard Dickinson
I have a new gasket purchased from Moss to go under the gas tank. The gasket is tapered. Does the thick side go towards the front or rear of the car? Also the retaining straps had some kind of hard board strips attached with split rivets to separate the strap from the tank. Any ideas about what to replace this with. I was thinking about using some thick gasket material and bonding it to the straps with gasket cement.
Hi Guest!
