Mitch_GT6+
1969 GT6+
Well, I need a bit of feedback on this one to point me in the right direction.
I lose power to my fuel gauge and my temp gauge, as soon as I tap the brakes. My brake lights also do not come on. Sometimes, I would drive for 30mins, everything would be good, brake lights and gauges work, then would stop.
I just replaced the voltage stabilizer behind the speedometer, same result.
This started last year where I would lose my gauges, but I didn't realize my brake lights weren't working.
I fiddled around with some wires and replaced some of those older splices with new ones (the green/pink wire I think). Everything there seems ok.
I've taken my "newly replaced brake light from a Ford about 10hrs ago" apart about 10 times, readjusted properly, everything looks good. Bench tested with Oh meter, all good. I do remember before changing it about 10 years ago, the power wire to the switch would get hot. Not so anymore.
One thing to note, my spedomoter sometimes moves in the dash, as I only have one of the threaded brackets holding it. I thought perhaps the angle of the voltage stabilizer wasn't ideal. So I taped the speedometer on the dash so it wouldn't move and no go still.
Interestingly, I did find a black wire with a loop on it, that was loose behind the dash. I figure it's a ground, so I grounded to a metal support behind the dash.
Maybe this should go on the threaded bracket that holds the speedo to ground the voltage stabilizer??
Would appreciate some thoughts so I can figure out my next steps.
Thank you!
Mitch
Thank you!
Mitch
