fuse and relay block
kcbugeye1275
This springs goal is an upgrade to the wiring. Anybody have a source for a 6 or 8 fuse block and maybe 4 relays.
Total custom harness or just an upgrade?
One of my MGB buddies has started to make a modern fuse box and relay kit for MGB's. I just bought one and it's very well done with original colored wiring etc. The big thing for me, in addition to the "modern" fuses were the relays, so that all the power doesn't run through my switches. I wonder if it could be adapted to work in Spridgets. Here's his site. Good stuff and priced well for what you get.
https://www.bits4brits.net/
Doesn't look half bad to me, especially since the cost isn't much more than the cost of the parts. Often, when people do this kind of thing, they use it as an excuse to really ream the less knowledgeable customer. That's obviously not the case here.
I suspect you could make this work on a Sprite, but you might have to do a little cutting and modifying. Hard to say how much--but in the worst case, you'd have all the stuff you need without having to shop around for it all.
