Hydronic baseboard oil furnace heating system, with tankless coil domestic hot water.
Took my shower and all was fine.
Turned on hot water for washing dishes, water came out hot, then warm, then around 80F.
Furnace shows tankless coil is 140F.
Raised room thermostat to 90F, furnace came on and began circulating hot water through the baseboard pipes.
But even when the furnace is running, there's no hot water coming into the sinks, bathtub, or shower.
Turned hot water mixing valve all the way to max hot (160F) - still no hot water going to domestic outlets. Turned it to minimum (120F), no change. The outlet from the mixing valve is only around 80F, altho' the water in the coil is 140F.
I'm guessing the mixing valve is stuck - even tho' it's only a few months old. Hit the valve a few times with a hammer, no change.
Any suggestions?
Thanks.
Tom M.
Any suggestions?
Thanks.
Tom M.
