&^%#$% Fule Pump!
Administrator
Boss
Drat! (sorry for the stong language). I was going to try to see where my Spit was leaking oil today, but before I could get it warmed up, I discovered my fuel pump is leaking like a sive! I have an after market electric pump and its one of those el-cheapo's you buy for $20 at Auto Zone! I don't mean the hose connections were leaking, I mean the actual body of the fuel pump. Anyone have any recommendations for a good replacement pump? (I do NOT want to go back to the original type mechanical pump).
Cheers,
I've always had good luck with Bendix (now Facit) "Blue Tops". They also have a similar "Red Top" fuel pump that should work. You'll probably need a pressure regulator if you don't already have one. If I recall correctly, you have Webers on your car - pressure for these should be 1.5 to 2 psi.
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by coldplugs:
I've always had good luck with Bendix (now Facit) "Blue Tops". They also have a similar "Red Top" fuel pump that should work. You'll probably need a pressure regulator if you don't already have one. If I recall correctly, you have Webers on your car - pressure for these should be 1.5 to 2 psi.<hr></blockquote>
Who carrys these? (Yeah, I have a regulator - usually set to 3psi)
Thanks, I checked them out. Looks like they have a fair selection. The little square Facet (Bendix) unit is similar to the one I have now.
Cheers,
Hi Basil, why don't you use a good old fashion SU pump. It is a British car isn't it?
Well you can get a very reliable adjustable pump from Holley. That's what alot of the street boys are using.
Dave C.
I have a Carter super pump in the Lotus.. It's a rotary style pump and they are dead reliable.. They make the regular and HP pump.. the regular one will do you..with a holley regulator. I also plumbed in a pressure guage, so I know exactly what my pressure is. ( just over 1 psi.. these things flow tons of volume so you can keep up with the carbs no problem at low pressure..)
They are a bit big and definately more noisy, but you will never have fuel delivery problems again.
Don't forget to put an oil pressure cut off switch in the line.. You can stop a lot of fires that way..
[ 12-02-2002: Message edited by: TypeRboy ]</p>
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by TypeRboy:
<hr></blockquote>
Splain how that works? When you start the engine, how do the carbs get gas when there is no oil pressure?
Read about half way down on this page to understand fuel shut-off switches:
https://www.holley.com/HiOctn/TechServ/TechInfo/FMFPTech.html
I’m using a Facet solid state fuel pump….very noisy, but very popular with racers due to reliability. I set my regulator at 2.5 psi for racing/street use. Got mine (and many $$$$ of other stuff) at the following place:
https://www.racerpartswholesale.com/
go to β€œcomplete index” and look for β€œfuel pump”
Facet Solid State Pump
FEP42S 1.5 to 4.5 psi - 1/8" fpt fitting - 15 gpm $45.99
________________________________________________
Also: Since some of you may not have seen my fuel regulator recall note, I’m pasting it in below:
Many of you have re-fitted your LBCs with aftermarket electric fuel pumps, and usually a fuel pressure regulator. If you have a "Purolator" or "NAPA" fuel pressure regulator, you may want to read the notice below. My race parts supplier (RacerPartsWholesale) send me a note about this last week....two of my cars have these regulators, and one of the devices was built during the affected interval, and will need to be sent back.
Number of Units Affected: 32518
Defect Summary:
PUROLATOR PRO~FUEL AND NAPA BRAND IN-LINE FUEL REGULATORS SHIPPED BY ARVINMERITOR FROM NOVEMBER 1, 2001, THROUGH AUGUST 31, 2002. THE ELASTOMER USED FOR A DIAPHRAGM IN THE SUSPECT REGULATOR IS NOT COMPATIBLE WITH AUTOMOTIVE FUELS.
Consequence Summary:
PROLONGED EXPOSURE CAN RESULT IN THE DEGRADATION AND WEAKENING OF THE REGULATOR DIAPHRAGM. AS A RESULT, THE DIAPHRAGM MAY LEAK FUEL, POSSIBLY RESULTING IN A VEHICLE FIRE.
Corrective Summary:
ARVINMERITOR WILL NOTIFY ITS CUSTOMERS AND REPLACE THE SUSPECT FUEL REGULATORS. OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING OCTOBER 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT ARVINMERITOR LVA CUSTOMER SERVICE AT 800-637-0580.
NHTSA CAMPAIGN ID Number: 02E056000.
