JamesWilson
I've a somewhat rusted fuel tank that I'm re-painting.
In stripping off the old paint I've found a pinhole.
The old tank seems to have had a similar problem that was fixed by liberally plastering fiberglass all over the tank's bottom. It looks lousy but seems to work.
There seem to be two other fixes:
1.) Take it in to a welding specialist and have the hole welded.
2.) Use a self-tapping screw and a bit of silicon sealer.
The first will probably take a while and cost more than it should, the second would be quick and easy and cheap.
Should I do it right and get it welded? Or join the ranks of DPOs with the second method? I'm tempted....
Then there's the back-up to both methods- once fixed, the use of some type of tank sealer....
Any opinions on tank sealing/sealers?
