Drill chucks were never designed to accept side pressures. If you try to do side milling with a drill chuck, sooner or later it will come loose & drop the cutter right into your work or worse.Jim_Gruber said:My biggest problem is the Chuck that comes spinning off and flying across the room whenever there is any type of side pressure on the chuck. Cheap Chinese Junk.
