After a year in heated storage, my '71 E-Type failed to start. No clicking from the fuel pump when I turn on the ignition, and the motor fires quickly when fuel is squirted into the carbs, so the obvious culprit is the fuel pump.
However, I also note that the red ignition warning light does not come on as it used to when I turn on the key, and the turn signals seem to have quit working as well. So before I pull the pump, is there a possible electrical problem cuasing all three problems?
I've checked the fuses, although there is no fuse on the wiring diagram for the fuel pump. I expect I should just test for voltage at the pump, but my trifocals have a problem focusing in that little hole in the trunk, and I'm not sure if it wouldn't be easier to just pull the pump.
Any ideas?
Thanks!
Jim
Any ideas?
Thanks!
Jim
