Deleted member 3577
If yer gonna run 1 3/4's....
Ya have to be sneakier than that
Racing has elevated cheating to an art form.
Time to step up :hammer:
You almost need a caliper to distinguish the difference between a H6 & a H4.
The HS6 is shorter and has that hose on the bottom.
Dead giveaway.
NOTE: BOTH require that you cut off the 4 stud holes and tig 2 of them back on (top & bottom)
So they fit the original MGA intake.
This is where the art come in....You have to be a sculptor who works in aluminum to make it look perfect.
HS6 is a "MGB carb"....WAY after Dec 1959
Dead giveaway.
