Fuel pump wired to coil?????
Dennis P
I just traced a mystery second wire, attatched to the + side if my coil on the 70 B. It runs into the harness thast goes under the car and to the fuel pump. This was traced because when I first hooked up the new pump, the tach went nuts, without engine running, as the pump started filling up the floats. the tach would swing up and down in sync with the ticking of the pump. Is this connection standard or a DPO thing. Once I fired it up she ran fine, but the tach continues to go all over the dial. Any thoughts?
My guess is DPO
You've got the standard blockhead wiring job there. Hook the pump up to a switched / fused circuit or make sure sure your weekends are free looking for phantom problems. Fuel pumps don't like being hooked up to the coil + for a number of reasons.
Duane
Get a shop manual, or a haynes or other complete beek (or book if you prefer). Trace the wiring schematic carefully. The comment about "blockhead wiring" is correct. You might have car repaired by the guy who got his degree at "Junk-Yard Tech". We all have made "temporary fixes" that cost us days of frustration later. Lose the coil wire hook-up.
