Fuel Pump - What's this?
SaxMan
Lately, I've been smelling gasoline in the garage after I fill the tank on the Sprite, definitely coming from the rear. I went through the fuel line from filler to the pump. I'm 99% sure it was a loose hose clamp on the filler tube, but while poking around the fuel pump, I came across a couple of things that I couldn't figure out. The BL Service Manual and other printed resources at home also seemed mute on the subject:
OK, I get that the line on the bottom goes to the carburetor and the line on top comes from the tank -- what is the rubber hose on the side? That appears to be some kind of vacuum hose. It is also not particularly well secured.
DSC_0010 by David Cohen, on Flickr
Then, I have this line -- possibly the other end? It's just hanging out doing nothing. Should this be attached to something?
DSC_0011 by David Cohen, on Flickr
Finally, a bit unrelated, as I'm getting ready for the winter overhaul, I've been mulling replacing the rear differential gasket. There's a lot of muck on the axle, but I can't tell if it is from a leak or just years and years of grime. I cleaned it up after this picture to see if I can spot any new leaking
DSC_0013 by David Cohen, on Flickr
Obviously, with replacing anything in the rear end, you have to pop the driveshaft out and replace the U-Joints. Since I am likely going to be pulling the motor within 12 to 24 months for a rebuild or replacement, I'm thinking that unless I have a major leak, I ought to wait until I pull the motor, since the driveshaft and U-Joints are going to have to come out anyway.
I'm shooting to get started on the Sprite after New Years
On the diff and axle, I'd bet years of grime. I figure as long as it's not excessive or there is a leak at the hub (into brakes), it's just part of that territory.
Saxman
your scaring the crap out of me
tell me there are jack stands just out of sight because a slight push on the car and your off that jack!
The small fuel pump hose is an air vent. They aren't always plumbed. When there is a tube present, the tube is typically vented to the inside of the passenger compartment where the air is supposed to be clean and dry.
This is not a fuel vent, it's on the air side of the pump diaphragm.
I believe the vent is routed to the trunk and terminates in a 'T' and short stubs. Can't provide photo as both digital camera and phone camera are toast. Does anyone make an inexpensive camera anymore? Guess no one needs them nowadays w/cell phones.
Don't worry -- jackstands are there and out of the picture frame. I had them at the spring attach point on the body. I could see how that picture on the bottom would look extremely scary.
Thanks -- the air hose does appear to route up into the trunk, but I couldn't find it on the other side. Still not sure what the open ended hose is by the fuel tank, though.
