jhorton3
I now think the issue with rough running is fuel starvation. Here's the setup: New fuel tank, metal fuel filter, Facet fuel pump, glass fuel filter at the carbs, going into 2 HS2 carbs with the jet adjusting nut turned 12 flats.
Here's what happens: I turned the key to the run
position and the fuel pump starts ticking...loudly.
Before it would quiet down when there was fuel
delivered to the carbs, which was usually an indicated
by the glass fuel filter being filled. Now it never
quiets down and the glass filter doesn't fill. There
is some fuel being delivered as I can see it flow
through, but not like I think it should. Driving she's
shuttering under load and that fuel pump is still
ticking loud like it's not building pressure with
enough fuel.
So when I get back from church I'll pull the filter on
the pump side and see if that improves things. If that
doesn't where to next?
enough fuel.
