All,
My BJ8 quit running about two blocks after a fuel fill-up. It appears that it is not getting fuel. My opinion is that the filter is blocked up after 95,000 miles and no cleaning. I can hear the fuel pump trying to pump, but it stops quickly (apparently after pumping up to pressure).
The fuel pump is an AUF 300 type. It appears that I must remove the Coil housing from the pump body, remove the filter, clean and replace it. I can do this without removing the whole pump by accessing it through the wheel well after removing the tire.
My question is: With a full tank of gas and the filter removed, how will I keep the gas from leaking out?
Any suggestions about the best way to do this procedure would be appreciated.
Thanks,
Guy Beaty
Thanks,
Guy Beaty
