TR2/3/3A fuel pump oil leak
T
TFB
I have a small drip at the fuel pump.I have replaced the gasket with a high quality material homemade gasket ,but still some drips.
Are there seals on the primer lever shaft or is it just a tight fit in the body,as I now suspect that's possible source.I have never had pump apart and rebuild kits don't show anything that looks like seals for small shaft for the primer.
Thanks
Tom
In addition to the gasket at the block there is a gasket at the top of the fuel bowl and also a diaphragm underneath the top cover which may need changing if it has been a long time. Get a fuel pump rebuild kit and change them out it is not difficult. Leakage can also occur at the fuel line connections. Bruce
Thanks Bruce,I think the bowl gasket and diaphragm would be gas leaks or no pumping.
Thanks Hammish.The gasket pictured in rebuild kit just shows bottom notch for lever,no small hole.It seems the hinge pin may be leaking but further inspection necessary.
Tom
Thanks Hammish.That split gasket is completely different than shown in moss kit for tr3 ,so now not even sure what pump base I have as its been years since gasket replaced.Im still not sure what the missing kit seal is that seems to be for diaphragm ,not hinge pin.
A dab of sealer May do the trick.
Someone mentioned excessive crank case pressure but with the draft tube I think that's impossible.
Thanks again
Tom
Thanks,Still not sure where this umbrella looking seal goes but good to know to get the premium kit for a future rebuild.
I believe the hinge pin's only seal is a tight fit in the body and if sealed I think it would take two seals.
Thanks
Tom
