I have a new pump and new inlet pipe and compression nut at the fuel pump of my TR4A—so I’m being careful. For a few weeks after installing, I’ve had no leak. But now, of course, it’s leaking very slightly.
My instruction sheet warns against over tightening. Quite frankly, I think I’m close to being too tight. And each slight turn seems to do nothing. And, BTW, I abandoned that fix of using two half-ferrules, filing them even, etc. That seemed eventually not to work so well.
So, my question: When do you folks “stop” tightening that compression nut for fear you’ll just strip the threads in the pump. Is there a good test for feel, or should I just grab that line wrench and have at it? I guess my best judgment would be to try a bit more, maybe another 1/4 to 1/2 turn, then give up and try a new ferrule.
Thoughts please?
Thanks guys.
Thoughts please?
Thanks guys.
