Fuel pump blanking plate
  • Thread starter Thread starter Guest
  • Start date Start date
I used 1 from a speed shop. Their all about the same. Make sure he uses either a gasket or an out of the tube gasket. I probably don't need to tell you this.
Easy to make your own out of 1/4" aluminum. Just cut to rough size then file along the edges. I follow up on my 12" disc samder then lap the edges using 180 grit around a block of hardwood.
Use the gasket as a template.
Frank Fisher also makes (& sells) them.
