Have had my 76B up and running and yesterday following a funeral I did (I'm a UM pastor) I came out and when I started up the B it started screaming like a loose fan belt (it was fine up to that point). Went about a mile and the Blessed Virgin Mary started coughing and spitting and finally just shut down. Couldn't get it started, even jumping. Finally had to have it towed (really wanted to do another funeral on PA 944). Checked battery and it was only putting out five volts. Recharged and checked alternator and tightened belts. After a little coaxing started up and ran fine with all electrics running. Getting good output from alternator (14+ v) and battery checks good. Shut off all the electrics, went in the house, came back outside and BVM started sputtering again idling, and finally died. Checked battery and getting good volts. Pulled off fuel line before filter and I'm getting no fuel being pumped up to carburetors (2 HS4s). Have noticed that fuel pump has been running like it was going to a race (probably ticking a couple of times a second - seriously). The fuel pump is an after market electronic and don't even have 300 miles on BVM since completely rebuilt (including engine). Any idea where I ought to start looking? Could I have a fuel line block somewhere. I plan on checking the fuel pump coming out of the tank area tomorrow. Any help would be greatly appreciated. Thanks
