I got a fuel pressure regulator, a holley 4-7psi unit, and then I tuned it to midway and it worked pretty well now(this is going into two MG B carbs on my midget thow) but you can tune it to what works. /ubbthreads/images/graemlins/smile.gif
This problem is kind of unusual. Are you sure the pressure gage is correct? The fuel pressure is set by the armature return spring tension. I can't imagine the spring increasing it's tension. Only other thing I can think of is that the diaphram itself has lost elasticity & is contributing to the overall spring force.
