Jim_Gruber
OK got new Mr. Gasket fuel pump installed and it is still really noisy.
1) New fuel filter in front of carbs
2) new 12 non ballasted coil
Started going for a test drive, engine misfiring badly , no power.
Turned around and came hoem and swaped floats off of my 1275. Misfiring better and more power. Started going down to get gas and engine misfiring kept gewtting worse and worse on way to gas station 2 miles down the road. Under no load it ould idle but ask for any power and it just would not go.
Turned engine off, filled with gas, and Bugsy absolutely will not restart. I'm guessing it's got to be points or condenser at the point. Bugsy spent the night away from home all by himself. Going down armed with new set of points and condenser to see if I can get him going rather than getting him towed.
Definitely getting enough gas. If fact coming out of overflow tubes as I tried to start the car. Pump is low pressure 2-3.5 PSI. Replaced old pump which said 5.5 PSI
Any ideas on diagnosis. I'm betting one of those bad condensers Kim was talking about.
Hi Guest!
