My 66 BJ8 fuel line is probably what started out on the car, but was also probably butchered beyond recognition in the ensuing forty years. It was attached to the pump by a length of rubber hose, cut in the engine compartment to accommodate an in-line filter, also with rubber hoses. There remains only one fitting, that which was brazed to the end of the line closest to the carbs, to which the braided hose connected. The line itself is 5/16" od steel. So here go the questions: What were original fitting arrangements between the line and the pump, and what is the correct routing? I know the line runs along the passenger frame rail, but that's about all I know for sure. And, if making new lines, is steel the preferred choice? Stainless steel? Thanks in advance.
Hi Guest!
