Didn't want to hijack the other thread on the gauge running empty. but, this was posted there
<span style="font-style: italic"><span style="font-weight: bold">"First, that gauge has to be grounded or it will always read empty. If it goes to hard full and the tank is not then that suggests a break or bad connection in the wire between the gauge and the sender. A bad ground at the sender will do the same. If it goes to hard empty then that suggests a short in that same wire. I really don't think the lights are related. Be sure you have a green wire to the B post of the gauge and a green/black to the T post. The case must be grounded. If you remove the green/black from the T post and check its resistance, it should be somewhere between 0 (empty) and 70 (full)." </span></span>
I run our of gas when the gauge shows 1/4 tank. it is a new tank and a new gauge (VB) what should I be thinking of doing?
