Folks,
Not really sure what's going on with the car. I have developed a hot start problem that I can't seem to figure out. Car starts fine when cold but after warming up is hard to start. Changed out fuel lines and filter just as a precaution but no change. Checked to see if the fuel vent was clogged but since this is a later car (CT 38104L) it apparently doesn't have a vent line. Does anyone know if the cap is vented? I did notice that the clear fuel filter I use (FRAM G2) appears to be empty when the car is hot. Over about 30 minutes it will fill up again. Also, when empty, I can see the fuel pulses in the filter. They don't look uniform meaning that they are mostly random. Could my pump be going bad? Any thoughts on what I should check?
thanks,
Greg
thanks,
Greg
