rlandrum
I've got a hole in my gas tank.
Should I replace the gas tank, or attempt to have it repaired. The rest of the bottom of the tank looks solid, although very pitted with rust.
https://xjguy.com/triumph/dec19/800x600/00004.jpg
It's a bit more than just a hole. The hole is about as big as a large screw driver blade, but then a crack extends on either end of it for about an inch. The metal in that area is as thin and weak as tin foil.
A repair would need to cover about 5 inches, starting at the edge of the tank and extending to both transitions front and rear. I think the damage is confined to just this one area.
