rick_ingram
Today did not go nearly as well as yesterday.
Worked on the 68 MGC. No fuel is getting past the float bowls.
Traced the supply of fuel from the tank all the way to the carbs.
Fuel will deliver all the way to the bowls.
After the bowls fill, there appears to be a lock of some sort happen...where fuel is no longer supplied to the carbs...I have a clear filter in the engine compartment and can watch the delivery trickle down to nothing. This happened with one SU fuel pump and two electronic pumps, each delivering #2 - #3.5 psi.
When I pull the feed lines to the bowls, fuel delivery is normal....into a pan.
The car would start when I tried spraying some starting fluid not only into the neck of the stock air filter, but directly into the carbs themselves.
I opened each bowl...neither was overly dirty.
Can the needle of each carb be varnished or blocked such that this will cause the delivery of fuel to completely stop....
No fuel is forced from the vent tubes of either carb.
Thanks in advance...
rick
rick
Hi Guest!
