Front Wing Bodywork Question
Tim_80B
Member
Hi folks,
I'm planning some body work and have a question about my front wings. I need to replace my driver's side panel from the chrome strip down. On the other side, the bottom 6-8 inches will be replaced. I will be removing both wings as part of some other minor body work (sill replacement /ubbthreads/images/graemlins/tongue.gif ) so when should I cut out the rusty sections and weld in the replacement panels? Do I replace the sills, then place the wing back on, gap everthing correctly, *then* cut out the rusty section and fit the replacement panel? Or start by cutting out and replacing the rusty section of the wing, then remove the wing, then the sill work? Seems to me this latter course would not allow the best fit with the new sill, right?
I also want to thoroughly strip and repaint the inner wheel well. I would expect that would be easier with the wing removed.
Any suggestions would be greatly appreciated!
Tim
Remove wing. Replace sills (heh, if it were only so easy!). Test fit wing or what is left of it. Do this about 10 times - no kidding. Cut off lower rusty wing remnant. Align new section, tack weld on. Test fit again. Grind off, retack, refit. Weld on new lower wing.
There ya have it!
Sounds like a good course of action. Thanks! I'm sure I'll have one or two little questions about the sill stuff once I get there. I've been doing a lot of soul searching and trying to screw up the courage to cut in...maybe in a week or two....
Tim
Look at it this way: you can't do any more damage than's already there!
