Jeepster
I noticed that my front wheels looked to be toeing out rather than in so went down to the laser alignment centre to check and adjust.
Seems the the toe out was about 4 mm so tried to adjust to the settings from the manual.
Even with the steering adjuster bar screwed as far into the track rod ends as possible, I could only get 2 mm toe out! I need more adjustment.
Is is there anything else on the steering that could put the tracking so out? I'm sure it wasn't this bad last year. Also, I'm unable to adjust and reduce the toe in any further.
