Front Wheel Bearingsknow
Rob Glasgow
I'm planning on replacing the front wheel bearings on my BT7 when I install new hubs and discs. I've had some issues with China made bearings in the past and would feel better with SKF bearings. Does anyone know the SKF numbers for both inner and outer bearings and races and the oil seal? Or have other had good luck with another brand?
A
IN most cases bearings are made to the number that appears on the bearing all bearing manufacturers may not make it but most main line vendors may if the item has broad usage ..
So search the bearing's number you may come up with a better brand.
I have a BJ8 and your front bearings may be different, but this is what I got when I changed bearings in 2002:
Inner bearing: SKF CK-LM67048 (Germany)
Outer bearing: SKF 11949 (Mexico)
The markings on the oil seals: NAK SC 2.062 2.875 0.375
Info from previous bearings, removed in 2002:
FRONT OUTER BEARING
REMOVED FROM LH SIDE 12 MAY 02:
OUTER RACE: MADE IN ENGLAND - TI > < TIMKEN O -LM11910
BEARING: MADE IN ENGLAND TIMKEN LM11949
INSTALLED IN LH SIDE 14 MAY 02:
OUTER RACE: MEXICO ….X SKF LM11910
BEARING: MEXICO ….X SKF LM11949
REMOVED FROM RH SIDE 2 MAR 14 (REINSTALLED SAME DATE)
OUTER RACE: MEXICO SKF X LM11910
BEARING: MEXICO SKF X LM11949
FRONT INNER BEARING
OUTER RACE: MADE IN AUSTRALIA 01 < TIMKEN LM67010
BEARING: MADE IN ENGLAND TIMKEN LM67048
OUTER RACE: GERMANY B G SKF K-LM67010
BEARING: GERMANY SKF CK-LM67048
OUTER RACE: GERMANY SKF K-LM67010
OIL SEAL: B1 72 53 95
