RobSelina
Having some fun fine tuning my brakes.
The system is basically stock except for steel braided soft lines. The MC was rebuilt a year ago. Front and rear brakes haven't been serviced in a while, but pads/shoes look fine front and rear.
Here's the issue - rear brakes lock up much quicker than the front ones. Depending on how well I have the rear brakes adjusted (left vs right) it will also pull pretty hard to the passenger side.
I've pulled the drums and I have an axle seal leak on the drivers side, it's dry on the passenger side.
I've been backing out the rear brake adjustment screws to try to ballance the front to rear brakes and also have her go straight under deceleration, but I'm not getting it very close and the e-brake is almost useless with the adjustments out that far. Regardless, I seem to lock up the passenger rear (the dry one) first, even with the adjustment way out...
I figure I need to fix that drivers side axle seal to even out the rear brakes, but as far as front to rear ballance goes I'm wondering what the best course of action is.
Were the brakes well ballanced from the factory? Since I don't kow how old the front calipers and pads are, would rebulding/replacing them be the first thing to try? what about a brake proportioning valve?
Any ideas or thoughts apreciated. I've been fighting this one for a little while and I'd like to get this little car to stop evenly.
