I replaced a couple items in my ('66) sprite over the weekend. It solved a couple problems and revealed a couple new, less urgent symptoms. Items replaced included a leaky LF damper and a clunky steering rack. The replacement rack was treated to new grease, gaiters and tie rod ends. The symptoms that those items fixed were a wobble at and over 50mph, a clunky and less than smooth turning steering wheel and an extreme jarring when going over a bump or hitting a pothole on the left. I am absolutely sure that the new symptoms are related to the recent work as there was nothing like them before hand. They are a disfunctional horn and a strange tendency for the car to seem to jump or bounce sideways across the road a bit when I hit a bump or pothole on the right. It's not jarring but the car's just not precise anymore and kinda feels like it skips. Any thoughts? Some other items that might help to know are that both the left and right front dampers were replaced last year with items from a vendor that is widely respected on this forum. All bushings were replaced with red poly within the last year and a half and the springs were replaced.
A write up of the work is linked to below.
Thanks guys,
Sean
Thanks guys,
Sean
