If you do the front bushes, you will need to do an alignment. I wouldn't count on having everything line up, even if you don't touch the tie rod end adjustment. It's not hard to do though, there's no camber or caster adjustment. I built an L-shaped 2x4 frame with the long piece going under the car, and the short piece up against the edge of the tire. Then I used a square placed along the lower 2x4 snug against the same point on the other tire, and took several measurements at different points on the tires after rolling the car back and forth. Crude, but it worked. To make sure the steering wheel was aligned, I first tied a string to a jackstand placed behind the rear wheel, then laid the string across the rear tire and adjusted the tie rod ends until both front tires were parallel to the rears. Again, I rolled the car back and forth and did this a couple of times. Once I got the steering wheel aligned I did the toe-in alignment, and the trick to keeping the wheel straight is to turn each tie rod by equal amounts. In my case the wheels needed to toe in a little, but only took about 1/2 turn on each tie rod. Hope this helps!
