front springs
bugedd
Does anyone know what the spring rate is on the BE front springs? I am looking at some used 340lb, but don't know how that compares with stock.
Thanks
wow, that would be way too stiff. thanks
340# are way better than the stock ones.
Match Peter C's Shocks and a front sway bar and drive the socks off of it. :driving:
Steve
Hmmmm....its only a $100 investment from some used ones I found, so I may give it a try. Hopefully lowering the car by 1" won't cause any clearance issues.
Should not lower the car, just increase the spring rate. YMMV
Good Luck
Steve
:driving:
