Hi Rob,
Keoke is "right on" about the bearing spacer. Because the spacer is in compression it effectively increases the diameter of the spindle. MGB also uses this arrangement. It "is" a lot of extra work to setup & adjust. I think that on most other cars, including Jag, the spindles & bearings are larger to start with, & this arrangement is not necessary. Remember, the Healey suspension was adapted from an Austin sedan which didn't have as much force put on the spindles as a sports car has.
This "lash up" does provide extra strength in a critical area & should be followed. A few folks just set things up as they would on a more conventional bearing arrangement, & ignore the shims. If you're not driving the car at the limits the extra strength provided by the compressed sleeve may be needed or may not. Denis Welch claims that over 50% of the stub axles that they have checked are found to be cracked. I assume that this is on race cars that put more stress on the axles.
