[ QUOTE ]
Any oil will eventually destroy the rubber seals in a shock...
[/ QUOTE ]
I don't understand that statement. I agree that any seal will eventually perish (entropy), but I don't think the oil is at fault. Anyway, the reason you check that there is a need for oil is because some may have leaked out. It doesn't burn, or disappear for any other reason. The shock should be a closed environment. The Armstrong shock lasts a very long time. If for some reason grit, salt, etc get onto the shaft seal area, the life of the seal (atually a packing) is compromised. Then they leak. There may or may not be a rubber piston seal inside. At most only 1. Never two, and often no piston seal at all by design. It is possible to overfill the shock such that when the oil expands due to heated use, it will weep from the shaft seal. There is meant to be an air-space. When that happens, that area becomes likely to attract the grit, etc. Best not to overfill. Changing the oil every decade or so is probably a good idea. I recommend a hydraulic oil as used in hydraulic heavy equipment. It has the antifoaming ingrediants and is quite stable. I suspect it's what is sold as fork oil. They are designed for hydraulic systems under pressure and heat. Available in many grades. We use 20w for road use, and 30w for racing, along with other tweeks to the valves.
But, I can't argue with your successes. It speaks well of the durabilty of the shock.
Peter
